JimPA
I thinking that there are two kinds of Tub Dap/Box Outs. When the rough plumbing in a basement is laid at the beginning of construction, I'm thinking that they perhaps have an outer concrete wall that the plumbing rests in (I'll call this the box out). But when you add plumbing after the fact, there is no outer wall, just a hole in the foundation to access the plumbing (I'll call this the dap out).
My house has the latter. We are adding a basement and the contractor has broken up the foundation to locate the waste line and has tied in. He filled back in all but a square hole that will allow the placement of the tub drain.
Originally, he said he wasn't going to fill it in at all, then he said he would add some gravel. But I'm concerned that it should be covered with concrete as well once the tub drain is set. I guess it wouldn't need to be a thick layer, but something that would protect against radon, water, bugs, vermin, etc.
I'm in Pennsylvania in case code comes into play. I would love for this to be the case so I wouldn't sound like a PITA paranoid customer. I've been told we always to it this way. I'll stand up for what I need, but I'm looking for advice to make my argument easier and perhaps also make sure that I can limit any additional cost (if what I am asking for is code or the norm rather than the exception).
Thank you.
Thank you.
