Cleaning off flux [better late than never]
Taylor
Northern Joisey
Soldered all the pipes of my main bathroom, got good input from here and will post pix when I am closer to completion.... At the end, exhausted, figured I'd wipe off the flux the next day, or the day after.... Anyway a few months later, putting on the pipe insulation and I see the tell-tale signs of green....
So my quick question is, is there a recommended way to clean off flux that has dried onto the pipe at this point? I've tried soap and water and a rag, the pipes still feel sticky in places (I had flux on my gloves as I was handling the pipes). At this point I'm thinking white vinegar and a pot scrubber, unless someone informs me of the error of my ways....
Oh boy.....
Drain the water first?
Do this the entire length of the pipe? I was handling it with flux-covered gloves, that stuff is messy. Although green is localized, I assume it may appear in other places later, like where pipe is sticky.
Any danger of accidentally undoing joints (solder flows out when I heat it)?
I've been able to remove green with a pot scrubber, just wonder if this is good enough. I know white vinegar recommended for cleaning up copper ornaments. Also heard of baking soda in water....
Does alcohol disolve it? I know that is what I use on electronics to remove the flux (but that is rosin, not acid based).
Reporting back: I can report that white vinegar and a pot scrubber do a good job of removing the green. It also restored a nice shiny lustre to the copper. Seems a shame now to cover with insulation and a floor.....
Thanks all for your help.
