York
Hello, can you convert your regular tolet to a tankless tolet?
Thank you , York
Thank you , York
You DO NOT. There is no way to make that conversion. And, since "tankless toilets" need a lot of water, your tank toilet does not have an adequate supply line to install a "new" tankless toilet either.
The ball valve is full port 4", so you can really plug that bad boy! We used globe valves, though, not ball valves, to run some flushing water.Toilets on submarines are flushed with manually operated ball valves (both supply and outlet), works great.
quote; Have you ever seen a toilet tank made out of a 5 gallon bucket? All the holes are drilled with a regular bit or a hole saw. Mount the parts in the bucket and bolt it up to a toilet bowl.
Sounds like something you heard about but never actually saw. Unless it was an "oval" bucket, you would have to work around the bucket to sit on whatever part of the seat that was till visible.
