GFCI on wet power tools.....
Chefwong
District of Columbia
Built in GFCI on my electric PW is acting up .
I'll need to read-up on GFCI.........but dare I just cut the damm plug off and put a regular plug on.
The unit needs to be GFCI protected, so if you remove the one on the cord and then someone else dies because of it you wouldn't feel too good.
For testing purposes, you could cut it off and then connect the cord to a GFCI outlet to see if it will trip that. The problem is with a molded plug, once you cut it off there is no going back.
If the motor has a ground fault, you might be able to detect it with a meter, but the problem may not occur unless the unit is running.
While not a 100% check, does the test button trip the thing? The whole idea of a GFCI is that it measures the current on the line in comparison to the neutral...it should be equal when running. If it isn't by more than a little (often in the 5ma (0.005A) range), then it will trip. This is less than the amount that will harm the average person. The things are generally pretty reliable, although it could be bad.
NO! It just might be trying to tell you something, but you are too stubborn to listen. Plug it into a GFCI outlet and see if that one trips also, although the PW's one could be a bit more sensitive and trip first.
Them 120V PW's are a joke anyway.
Cut the cord off and save it.
I actually prefer the electrics.
Nice and quiet.
I have 3 PW. One monster GPM/PSI gas for the outdoor.
One 220 Electric .
The one is question is a 120V Camspray unit. Not the $99 karcher special....
Nice and quiet.
One 220 Electric .
All the 120v ones are about the same, You can't get something for nothing.
They are Tinker Toys, as you can tell.
I just got around to futzing with it.
No power, even on a reset.
I assume that the plug is bad.
Next steps, cut the cord, put regular cord into it, plug into a GFCi outlet and then confirm it's good ?
There should be a breaker an the rear of the motor, Is it tripped ?
