simko1940
Thanks for checking this question out. I'm remodeling.
It's a small bathroom in an old house.
Used to have a tub, toilet and sink. I took out the tub and want to make it a shower stall.
From this angle the shower will be on the left, then the toilet in the middle, and finally a sink unseen and revented on the right.
However, I'm not sure my pdraining and venting is correct.
Should the shower drain on the left have a p trap?
Can I tie the shower into the toilet like I have it now? I'm doing this to avoid notching the joist further.
Should I vent the shower or is the wet vent run short enough to use the toilet drain? It's 1.5" pipe and about 3' to the main stack.
The vent stack goes to the roof and is in good shape.
Thank you for any advice you can provide.
