haloguy628
Hi, I found this forum searching for solution to my problem. Great forum and excellent info.
I just replaced old iron cast double sink with SS one bowl sink. The problem is that the glued rough in drain plumbing is at an angle as it was aiming between the old two bowls. Now the drain is directly under the single sink drain hole and in the way of the garbage disposal. I am attaching two pics so you can see the setup. What I need is for the drain to sit at 90 degrees to the wall (straight out).
I am open to any and all ideas including calling plumber if the job is too complex. Thanks.
