How much pressure is too much?
jm1414
My deep well tank used to stay between 35 and 45 PSI. Now it is often in the 80 PSI range. Is this a cause for concern? Should I attempt to get the pressure down or have the system checked by a pro? My tank is a wellXtrol WX202 rated as 100 PSI max.
PS There is no problem at all with water pressure in the house.
Thanks for your help
Jean
Well, I'm not a pro, but here are my two cents: if your pressure gauge is correct, then it could be either the T to the pressure switch is partly clogged, and the pressure switch can't respond promptly, or the pressure switch is either bad or not adjusted. They don't change (much anyway) on their own, so unless there is a (partial) clog, maybe a new pressure switch? If the pipe is galvanized and old, it can fill up with rust and create numerous problems.
I'm with Jim on this. If the pressure is indeed that high, take a look at the pressure switch. It may not be reacting as it should to the pressure.
Rather, and I see this all the time, is that the pressure gauge is bad and is giving you false readings.
Ron
Thank you to both of you!
I guess your conclusion is that I should be on the safe side and change the switch. I'll try to dig out some info on how to get that done without flooding the basement.
Thanks again
Not exactly...the switch could be fine. If the pipe it is attached to is essentially clogged with rust from the galvanized pipe (assumingit is galvanized), the switch can't react properly. Turn off the circuit breaker to the pump, open a faucet and let it run until the water stops flowing (you relieve all pressure on the pressure tank), then unscrew the gauge and pressure switch. Check the pipe to see if it is clogged, fix, replace, repair as necessary. If it is not clogged, then it is probably the switch. Again, my unprofessional opinion.
