Hi all,
I am trying to finish a kitchen remodel, for which I did not intend to change any plumbing. However, since I went from an overmount to an undermount sink, I can no longer fit a garbage disposal and/or dishwasher WYE. In both cases the drain pipe is too high relative to the sink.
My old sink was connected to the drain pipe shown in the first picture below. The drain pipe went into the wall horizontally at a 45 degree angle and I connected to a vented drain pipe which was about 19" to the right.
After exploring the plumbing in more detail, I noticed that the current drain pipe has a god amount of corrosion on the end, and that there is another drain pipe right behind the sink in the center (where one would expect a drain pipe to typically be).
Looking upward from the basement (3rd picture below), I confirmed that there are two drain pipes for the sink. It is unclear it the "dummy" drain pipe on the left is vented since there is a window right above it. Also this drain pipe connects to the basement sink.
Questions:
1) Why would the "dummy" drain pipe not be used if it was there in the first place, but instead the awkward angled horizontal drain pipe is used?
2) What would be the best way to lower the drain pipe so that I can fit a disposal to it normally? Do I just cut a hole in the wall, cut the drain pipe and insert a fernco and/or PVC Y at a lower point and then run a similar horizontal pipe to connect to the sink? This would essentially shift the drain pipe previously used downward and allow correct connection for the disposal.
3) Is this a doable project for a novice plumber but an overall good DIY'er? How can I make sure to do this in a quality fashion and up to code (I live in Minneapolis, Minnesota)?
Any help and advice would be greatly appreciated. Thanks in advance!
![CropperCapture[9].jpg CropperCapture[9].jpg](https://terrylove.com/forums/data/attachments/11/11806-5ef4d878cf0881cb1be22ac71fb65279.jpg?hash=XvTYeM8Igc)
![CropperCapture[10].jpg CropperCapture[10].jpg](https://terrylove.com/forums/data/attachments/11/11807-32e504dc6867b785ffa7da50b5894df6.jpg?hash=MuUE3Ghnt4)
![CropperCapture[11].jpg CropperCapture[11].jpg](https://terrylove.com/forums/data/attachments/11/11808-752b02ff15a3c476219f98aa448bd567.jpg?hash=dSsC_xWjxH)
Questions:
