Expansion tank location with a new tankless water heater
hokieamonglions
PA
I'm interested in the best place to put an expansion tank in my cold water line with a new tankless water heater install.
Currently with my tank water heater (to be replaced), an expansion tank is located right next to the cold inlet to the unit. The way the house is set up... Cold water is fed to bathrooms, kitchen, showers, etc, then on that cold line the expansion tank is next and then the HW heater. So in the big scheme of things... the expansion tank is located between appliances/faucets/etc and the cold water inlet to the HW heater.
With my new tankless HW heater unit, I will have the following configuration. Cold water will come into the house, go to a water softner. Out of the softner, cold line will go to the new tankless HW heater unit, then continue on through out the house to feed cold water to appliances/faucets/showers/etc.
So here is my question. Should I install the expansion tank on the cold line between the water softner and the tankless HW heater? Or. Should I install it between the continuation of the cold line after the tankless HW heater and the rest of the cold line faucets/appliances/etc? In either case, I plan to install the expansion tank to be within 1-2 feet from the cold input to the tankless HW heater. Or. Does it really matter what side....as long as it is close to the tankless HW heater?
Sorry if long winded, hopefully I explained my question enough.
Thanks in advance for any help.
"HokieAmongLions"
i think you can put it on the hot side as well if that makes installation easier... that's where my plumber put mine and it passed inspection. after HW tank, before fixtures, and before radiant floor heating loops. i'm not sure about the code on this, just where mine is and the inspector didn't say anything.
The real question is do you even need an expansion tank with the on demand water heater? While it will not cause a problem, the reason for the tank is to protect against thermal expansion due to the heating of the water. Now with a regular HWT you have a large amount of cold water being heated while the system is closed so this causes thermal expansion and thus an expansion tank is a good idea. With on demand however the only time the unit is heating water is when there is an open hot water tap, then when it closes the heater shuts down. If anything the static pressure would actually decrease slighty as the water left in the pipes cools down.
hmm, good point. i haven't ever actually installed a tankless yet, so never interacted with it this way, but i think you are correct, there should be no need for one at all.
i was going to use one in my house remodel, but with the radiant floor heating, it just doesn't make much sense to go tankless. huge inefficiencies are created with the tankless in this application. for potable hot water though, they definitely seem like the way to go. i'm hoping that we'll see them actually lasting the 20 years they're claiming, that would seal the deal that there's no other way to go for potable water.
Thanks.... My gut was that it wouldnt matter where... but after checkvalve... but wasnt sure.
Thanks again everyone.
BTW.....Jerome2877...
Previous thread question that I posted months ago... the answer was yes to put one in.
Link....
https://terrylove.com/forums/showth...-a-Navien-210A-unit-and-Expansion-tank-needed
I don't know one way or another about this, but Jerome's point seems logical to me. Maybe code does not differentiate and requires one regardless, I don't know. But can anyone explain why (in the real world, not code world) you would need one?
Thanks
Some tankless units actually have a small tank in them, and then, it would be a good idea.
The potable water expansion tank is designed for cold water...installing it on the hot side will shorten its life a lot.
I think the reasoning for code requiring one on a tankless unit would be to protect against a home owner either changing to a tank or adding one in the future. I'm not saying you shouldn't install one(as code does require one), I was just thinking about it and was interested in other opinions.
The reason for a "code" requirement is because many agencies do not "THINK", and once they decide something is a "good idea" make it manditory for EVERYONE so they do not have to decide whether it is needed or not in any particular installation. That way the inspector can just look for it and if it is there approve it and if not turn the job down. Tankless heaters with small tanks use it for recirculation purposes and it creates a minimal, if any, thermal expansion. In any case thermal expansion does NOT occur unless you have a closed system in the first place.
What HJ said about the volume of mini-tanks- a coupla quarts isn't going to need an expansion tank any more than 50' of half-inch plumbing does. They designed those in to avoid the "cold water sandwich" scenario, where a slug of cold water passes through the tankless unheated during the ignition cycle creating an annoyingly varying temp at the tap after a few short-draws.
Tankless heaters can be used in radiant heating applications with reasonable efficiencies, but like anything else it has to be designed & implemented correctly to get the efficiency out of it. If you have a radiant floor heated by a condensing boiler, an indirect fired tank HW heater on the boiler would usually be a better/cheaper/more-efficient system than adding a tankless. Short-cycling losses on tankless HW heaters are high (the EF test over-rates them), and the standby losses on an indirect tank are low.
Just wanted to add that, I don't have a recirc pump on the DHW.
At first thought, I would agree no thermal expansion tank needed with tankless heater. BUT, my 33 year old tankless heater which has performed flawlessly until now is faced with a big problem. The temp-press relief valve is now blowing occasionally. Replaced with a new 150psi valve. Still blows a quart or so every once in a while. Also, pilot light on tankless is now going out occasionally and eventually we noticed every time pilot goes out there's a puddle on floor under heater. Took another month or so to figure out what's going on. We recently got a new high efficiency washing machine. Each time we do laundry, these problems occur. Even on cold wash cycle, it demands some hot water to temper the wash water to about 60ºF. It does this by asking for short bursts of alternating hot water and cold water. After several short cycles of hot water followed by shut off and taking in cold, the full flame for a short time on the tankless leaves the heat exchanger stinking hot with no demand for hot water. The water in heat exchanger boils, has no place to go and lifts the T&P relief valve and the ECO cutoff switch in the tankless outlet cuts off the pilot light. I am going to try installing a thermal expansion tank on the hot outlet side to see if I can correct the problem. If this doesn't work, either have to get rid of the new washing machine or the tankless heater.
This is a really old thread, but I'll give my 2 cents. My understanding is that the expansion tank is required for a recirculating system only, because "looping" the hot water pipe back into the hot water intake creates a closed system, which then requires room for thermal expansion. The bladder in an expansion tank has a internal bladder under pressure, which is usually a few PSI greater than your main's water pressure (upon review, some say 10-15 PSI above, and I might do that on mine). Compare the two Rinnai installation diagrams below, the first is for a recirculating system, and the second, for a simple tankless hot water system without recirculation. There is no expansion tank in the second diagram. I could be wrong, but apparently a non-recirculating system can handle the hot water (because, I guess it cools in the pipes), while a recirculating system is line one, large boiler consisting of a bunch of (in my case) pex pipe and end of the line valves (a.k.a. faucets). If you have a recirc system, you add the expansion tank, and you still have the relieve valve popping, I'd suspect another problem in the system. For example, in a Rinnai recirc unit, the pump is supposed to stop pumping once the hot water return to the water heater intake valve reaches a certain temperature (107F is my recollection). If that feature failed, the water might continue to heat much higher, until the unit it self stopped operating to protect itself or the relief valve opened. An open pressure relief valve and water on the floor is a strong indication of a problem with the unit. If your 33 year old unit has been flawless until now, I doubt the expansion tank is the issue, or at least, not the only issue.
