KW
11-28-2005, 10:36 AM
I have two PA AS toilets (2 piece) that I just installed replacing some gravity feeders. One works fine, the other will not empty, and doesn't seem to have as much air/umph in the stream as the working one. I checked the basics (water pressure etc) and went through the trouble shooting in the repair guide - cleaned and checked the screen on the intake, checked the duckbill valve, checked for leaks etc.
The only thing that looks potentially awry is when I remove the tank and look at the connection, the two small holes that carry the water down to the bowl seem to have some stuff left over from the casting and are not as open as I would expect (I'd equate it to clogged arteries...). Could this be the cause?
Thanks in advance for any help...
KW
KW
