How do I remove a leaded in drain?
Pktaske
New Jersey
I've got some pics here and an explanation of the problem. My Kerdi drain wont go over the brass(?) fitting and is leaded in. When I started chipping around it, I encountered weird fiberous concrete. I worried is asbestoes although its most likely a fiberous form pipe that they put down before pouring the slab...right?
Even if I end up chipping down about 3 inches, how am I going to get this fitting out of the cast iron? Thanks...
http://www.johnbridge.com/vbulletin/showthread.php?p=1137018#post1137018
I've not seen a drain like that, but if it is leaded in you will need to get a torch to heat the joint from the inside to melt the lead. The bigger problem is THEN what are you going to do to get it back to 2" pvc?
I cannot see what the dimensions of things are there, but me thinks you are going to have to break the floor to install a new trap and riser on the drain pipe.
