Distance between toilet tank and wall vary for 2 toilets?
ken.yong
New Jersey
My plumber just installed 2 toilets in 2 different bathrooms. Same model from Toto Unifit. However, the first one has a distance between the wall and the toilet tank of 1 1/8"-1 1/4" and the second one has a distance of 3/4" only! Is there something wrong with this?
Is there anything I can do to adjust the distance from 1 1/8" to to 3/4"? I can't move my rough-in.
The same problem exists with toilets that do not use the Unifit adapter. You're pretty much stuck with what you have.
I have been searching the internet, trying to look for a solution and found the following:
Response on Wed, 25 Jun 2008 09:36 am by massplumber2008 suggested ["SCOOT" the toilet back just slightly to minimize the distance from the tank to the wall]. Is this a feasible solution? Will the toilet eventually leak because of this?
You can sometimes "gain" a quarter of an inch or so, but that's about all. I really don't think there is a viable solution to this "problem", and frankly, it's only a problem in your mind. I know it seems like a big deal right now, but no one but you will ever notice it, and you will soon forget about it and find something else to worry about.
Ken,
The plumber installs a drain in the floor, and then the toilet is set on that.
Like Gary above mentioned, you might be able to shift it 1/4"
One of your toilets has the flange set pretty much exactly at 12", the other one is sitting further away from the wall. The UniFIt adapters come in 2" increments, and nominally have 3/4" behind them when the flange is exactly at 10, 12, or 14" and you use the appropriate adapter. You don't have enough room to go to the next adapter. So, unless you can get the plumber to move the flange, that's it (other than the slight gain potentially possible by shifting the adapter). Note to move the adapter, he'd have to drill 4 new holes in the floor, and that can be a problem in itself. I don't thing the holes in the adapter are big enough to slide it, and anyway, if you move it, you have to remove it to replace the wax ring. Different toilets will have various space behind the tank - what you have isn't a big deal in most cases.
If the wall behind it is a small area and you are really concerned about it, hang a new piece of drywall over the existing wall. That will make up the difference and may be easier than moving the drain on the floor. Drywall is usually about 1/2" thick so it would make up the difference.
Thanks so much for all the replies!
One last question: Is there any way to check/test if the toilets are installed correctly? Currently there is no water leaking from the base after I flush. Is this a sign that the toilet is installed correctly? Or do I have to wait longer? Or any other tests that I can use to check?
Thanks again.
About the only checks are pretty simple. Is the toilet resting on the floor all the way around? Is is solid...not wobble or rocking? There should be no leaks from the tank to bowl connect (two piece only) and no leaks from the water supply line. The only place you can't see is the connect to the flange, but if the flanges is at the proper height or very close to it, and the wax ring needed to be compressed when the toilet was set, you have to have faith that it won't leak there. I've never installed a Unifit adapter, but assuming the installation instructions were followed, it's not likely to be a problem. I think you're good to go. Pun intended.
