Garbage disposal just put in, smells bad. Help please.
jitterpug
NC
A friend installed a garbage disposal for me yesterday.
When I got up this morning and opened my bedroom door, the odor was pretty strong coming from the kitchen.
I have cleaned it out at least 10 times, using vinegar, dish soap, hot water, cold water, etc.
There is at least 1 inch of standing water inside the disposal.
I think the exit pipe from the disposal should be going down not up. Could this be the problem?
Here it is:
Dishwasher is located on the left.
Evidently your friend hasn't grasped the concept that water flows downhill. That is exactly the problem.
You are going to have to lower the drain outlet (in the black pipe) and replumb that mess for things to
work correctly.
Thanks for the response. I'd like to ask which is the best way to connect.
If I come straight across it will land exactly at the pea trap joint.
Will I have to lower the pea trap/ entire assembly, or can I run it lower back (see pic) and add additional pea trap?
What is best?
You have room to lower the connection of the waste arm into the down pipe. That will allow the disposer to drain through a downturned elbow...much perferred to even a straight across connection as you suggested.
work correctly.
That may not be the only problem. It looks like there may be a AAV above the sanitary tee that could have failed.
John
Ok, so like this then?
http://i53.photobucket.com/albums/g63/billyhorse69/misc/disposal3.jpg
Sorry for the multiple questions, but I've never had to figure this out before.
I'm very frustrated with it, I thought my friend could do it.
I paid him $50 for the pipes which he bought at Lowes. Now I must buy more.
Plus the smell is maddening in here.
Can't do two traps. Drop the existing tee down to where you show the new tee in your drawing. Lower the p trap, use a longer tailpiece from the sink down to an end outlet waste.
I see. I thank y'all for all the help.
He is finally here again to work on it.
I shall show him this data.
Will let you know what it ends up looking like.
