wholeinone04
I am trying to remove the brass mounting nut from the underside of a widespread faucet in the bathroom. There is not much room under there and I was unable to take the nut off with a regular wrench. I tried a basin wrench, but again there wasn't much room to get the basin wrench in around the nut. I also bought the RIDGID faucet installer tool but the valve is too big for the shaft of the tool so I can't even get the tool up to the nut. The nut may be around 1.25" and the tool is 1 and 1/16".
The plumbing is probably about 20 years old(original). What tool do I need?! I am not sure how they even installed the thing! The only way I can think of is that they installed them on the sink and then laid down the sink. I do not want to remove the sink! Not sure if this is a small project or what. Is there some type of slotted socket wrench out there? I see shower valves that are 1 to 1.5" that would work for the spout nut, but the hot and cold nuts have valves out to the side, so there needs to be a slot. Should I buy a shower valve and then cut a slot?(Don't have any metal cutting tools though)
