Clearing line when pulling old toilet
magnumip
los angeles
I figured maybe it might be a good idea to insure the line is nicely cleared while I have the old toilet pulled.
I have a snake and could make good use of it while the wc is pulled. :cool:
My question is this. Lately I have been using a cobra expanding water blatter attached to a hose at the clean out in the kitchen. If worked better than the snake does most of the time.
How about using this set up at just inside the closet flange while I have the toilet pulled to install a new one?
That bladder pump would help if you had a wad of tp stuck in there. It will do nothing for crud buildups.
Running a stream from a garden hose into a 3" or 4" line for a water closet would likely do nothing to clear the line, there is simply not enough volume or pressure coming from the hose.
A 3 or 4" cutter head on a rodding machine might make your efforts more worthwhile.
What catcher_chick said plus forget about you hand powered snake. These are too puny and too short to clean a drain. It needs to be cleaned clear out to the street.
I agree with the rodding machine. The only reason I asked this is in the past it has cleared well from a 3" kitchen clean-out where a 3/4" snake did not work.
The bladders release a quick surge of water which can poke a hole in a clog, but does not necessarily clear it. If you continually get clogs, there's likely something else going on - an improperly sloped drain, or a break, or a crushed line.
