vibrating pipes - How to figure out root cause and fix it?
Tnkrer
When we flush or water the grass or start the washer .. the pipes vibrate. As long as water is flowing. When the washing stops or flush is done, vibrating stops. No vibration is heard for kitchen faucet, bathroom faucets, shower or even dishwasher. So when the water flow is above certain volume/speed it seems to vibrate. When reading about water hammer, it talked about when the valve is closed suddenly. The vibration does not happen after the water flow stops. So I am thinking its not water hammer?
Anyway, how can I go about finding and fixing the problem?
Thanks
A PRV would be somewhere after the water meter and most likely would be your responsibility. I've never been to your house so I can't really say where it would be but I would look in the basement (if you have one) near the water meter. Sometimes they are plumbed after the outside hose bibs but not often. If you replace it and the noise goes away, that will confirm it is a bad PRV.
If you have a PRV and you can locate it, then turn on something that causes the sound and feel the PRV. If it is vibrating that is the source of the problem.
