JeffeVerde
I'm building a cabinet front for a drop-in tub, and wondering if I should make it removable for the purpose of future plumbing access. The floor is slab-on-grade, and half the tub projects into an exterior bump-out, with interior walls bracketing the tub on boths sides where it projects into the room.
The underside of the deck-mounted faucet is accessible from a chase area, but access to this chase requires removing a built-in cabinet (remove 2 screws and slide the cabinet out of it's opening). This chase area also provides access to the interior of the shower plumbing wall (see attached sketch).
I can design the tub front to be removable or to have a removable panel, but it would complicate the design and the aesthetics. Is the chase (and removing a built-in to access it) sufficient for future service needs? The chase is large enough to stand (and kneel) in, but the built-in is directly above the faucet, so with the cabinet removed, you can simply reach in the hole and under the deck to access the underside of the fixtures.
