View Full Version : Toto Aquia vs. Aquia II vs. Aquia III
nonothing
10-24-2011, 08:34 AM
Greetings,
Can't really tell the differences between these models, other than rough in options, height differences, and glaze options. The company has not been much help either from the website or emails. Anything relevant to its function, and/or its price?
Also, what info would you want to give the contractor installing one of these for the first time?
10-24-2011, 09:02 AM
The Aquia 111 bowl is 1" higher then the Aquia II bowl.
My son James did a nice set of instructions for the Aquia; which after we had dinner with Toto in the Summer of 2010, they did a "copy paste" of and modified their instructions with his corrections.
Here are Jamie Love's instructions (http://www.terrylove.com/forums/showthread.php?12606-Complete-Toto-Aquia-installation-instructions-written-by-Jamie-Love)
crcurtis
10-25-2011, 08:20 PM
My plumber just installed one of my many Toto Aquia II toilets and it is sticking out almost 3 3/4" at the tank. Obviously they installed the flange too far from the wall.
I want to pull it back in but it appears that an offset flange or whatever will not work. This is from the plumber so I am sceptical since he messed it up in the first place.
Any advice as I prefer to have the back of the Tank about 1" from the wall.
Please help as I really do like the Toto Aquia toilet...
Curtis
jadnashua
10-25-2011, 08:49 PM
If the flange was exactly 12" from the finished wall, the toilet would have approximately 1/2" behind it. So it looks like it is close to 15+" from the wall. Unless you move the flange, not much you can do about it. One of the Toto's that use the UniFit adapters could move it back a couple of inches, but it would still be further from the wall than you want.
crcurtis
10-25-2011, 09:42 PM
He says it is 13" since that is what he usually allows for Kohler toilets...so either something is screwy or he has not installed it correctly. I guess I need to have him pull it and measure it myself.
Does the Aquia II work with the Unifit Adapter?
jadnashua
10-25-2011, 10:04 PM
If it was 13", at least based on the spec sheet (and on Toto, they're usually close), there should be about 1.5" behind it. No, the Aquia does not have various adapters...it only has one, and it is not the Unifit (which comes in 10, 12, and 14").
