View Full Version : Outdoor carpet adhesive question
Macman
10-16-2011, 03:04 AM
Not exactly a remodel question, but the best place for this question that I could find. I'm going to put olefin outdoor carpet on a covered concrete porch (stoop). It sounds like the accepted method is to use an adhesive made specifically for this purpose. If 5 years down the road I want to replace the carpet, is the adhesive going to make it darned near impossible? Just wondering what this stuff is like, and if there's any kind in particular that you would recommend.
jimbo
10-16-2011, 04:01 AM
Henry's 663 should be available everywhere. http://www.wwhenry.com/content.aspx?id=130&View=Product&cID=93&pID=130&ProductID=110
It has a 10 year warranty, so it doesn't give up without a fight! When you want to take it up , a serious amount of elbow grease and chemical adhesive remover may be required.
Macman
10-16-2011, 07:45 AM
Not really what I wanted to hear. :) I know that normally you'd want an adhesive that lasts "forever" but carpet doesn't, so I have to also look to the day that it might have to be replaced. Good information though, and I appreciate the response jimbo!
IF the concete is "smooth" then a wide "razor" blade scraper will remove it sufficiently for the new floor covering.
Macman
10-18-2011, 02:12 PM
Thanks HJ. I just ran into a snag. This past Saturday the concrete was sealed with a clear liquid solvent based sealer. Today while we were shopping carpet the salesperson informed me that we might have an issue with the adhesive not being able to stick to the sealed concrete. I called Henry and DAP to see what they had to say. Henry's answer was that it needed to be "tested on a small patch" to see how it works. That was pretty useless information in my opinion. DAP said that it would not work, period. I think we've messed up by trying to protect the concrete, in this particular case.
jadnashua
10-18-2011, 03:10 PM
Any foreign substance can affect the bond. Some sealers contain stuff like silicon, some contain oils, and some may contain waxes. Whether the adhesive will be able to bond is a tough call without knowing the exact components of each. The chemistry can be complex. You'd have a similar problem if trying to tile it...the thinset might not bond properly, either, and if the surface got spalled, you probably couldn't use a repair layer. When building something, every step can have consequences, some good, some bad.
You'll only know if you test it.
Macman
10-18-2011, 03:33 PM
Truer words were never spoken. I just talked to my brother. He suggested that it might be possible to sand the sealer off and rough up the surface with a rotary sander with a course disc. We also discussed how maybe DAP and Henry were taking the safe way out by not saying that it might work okay. I really have to wonder just how much adhesion we would get. Do you have any specific method that you could recommend to test it?
