View Full Version : Studor Vent Help
finn
11-22-2005, 02:43 PM
I'm adding a dishwasher about ten feet directly across from my kitchen sink. Drain line is 1 1/2"
The drain line connection is no problem and I plan to use the proper slope to the main drain line. Per the advice of my plumber I'm adding a studor vent to this line as well.
Here's the issue: If installed within 18" of the trap, as told by my plumber, the vent would be unacessible for repair.
So, I called my plumbing inspector and he explained I could install the studor vent up to 48" inches from the trap. Is this okay?
Thanks for the info. I'm confused...
bigrebnc1861
11-22-2005, 03:38 PM
If your inspector said you could do it yes you can. As long as your studor vent is installed at the highest point looking up.
Mike Swearingen
11-23-2005, 09:08 PM
www.studor.net
11-24-2005, 05:45 AM
The Studor vent is technically a "vent termination" so there should be no distance limitation. In fact some manufacturers recommend running all the vents normally, and then tying them together with a single Air admittance valve to eliminate the hole in the roof, except for the one required vent through the roof.
