View Full Version : Elbow With Low Heel Inlet to connect Tub & Sepperate Shower
Erc
09-16-2011, 11:57 AM
Can an elbow be used with the heel inlet in the vertical position for connecting 2 drain lines such as a separate shower and tub. I have seen posts that say this is not the intended use for this fitting, however it works, and that better practice would be to use a sanitary T with side inlet? The vent would be coming off the tub line a few feet away from the fitting. Everything connects to a vertical drain going to the floor below. I am trying to avoid drilling more holes in floor joists that are already drilled to death! Thank you.
13975
09-16-2011, 04:57 PM
In theory it is the same as a full sized sanitary tee with a bushing, but you would have to run it by your inspector because some do NOT like heel inlet 1/4 bends.
Here is a tee with a side inlet.
http://www.terrylove.com/images/abs/santee_right_side_inlet.jpg
