View Full Version : soap dispenser
Barry J
08-21-2011, 05:03 PM
We are having new granite countertops put in with new stainless sink. We were thinking about putting in a soap dispenser into the sink, but heard if the pump breaks ..it's hard to find replacements???
Any suggestions??/
Thanks
Barry
jadnashua
08-21-2011, 05:32 PM
Buy a quality pump! The hole size required is often fairly standard, so if worse comes to worse, you could replace the whole thing. I've got three Grohe units that are now between 5-10 years old (two different remodels) that are still going strong. The pump head is (or at least was) solid chromed brass, not plastic (although the guts are plastic).
08-22-2011, 09:59 AM
Almost all of the dispensers use a "generic" pump. About the only difference is what the "handle" looks like and that is usually interchangeable on the pump.
provem
08-29-2011, 04:58 PM
Hj is right. It is easy now to look for replacement for pump. When you buy a pump make sure that buy the type that has lot of look a like.
mfox11
03-23-2012, 11:17 AM
Yep, it's all about the quality of the pump... but still shouldn't be that hard to replace, most pumps are standard (in size and make). Bought 3 of these soap dispenser pumps (http://www.thebathoutlet.com/Soap-Dispenser/Chromed-Brass-Surface-Soap-Dispenser-628_Geesa-628~Buy), one broke but was able to get it replaced without a problem.
