View Full Version : Blower not turning off
jerome8283
08-13-2011, 08:03 AM
Got up this morning and my central air blower was running but the compressor was off. It seems to be switch related because the compressor did come back on after the temperature rose. Usually when I turn off the air from the thermostat the compressor and blow turn off. Now the compressor turns off only. What could be the problem?
jerome8283
08-13-2011, 08:20 AM
Fan setting was not set to auto! Problem solved! :)
LLigetfa
08-13-2011, 08:40 AM
An easy fix and one you'd kick yourself for if calling out a tech.
My wife called out a tech for an intermittent furnace problem where it would run for less than a minute and shutoff. The tech tore the furnace apart before realizing the problem. Turns out the wife tossed a blanket on top of the garbage cans that where right below the fresh air intake for the furnace. The wind was blowing up a flap of blanket that would sometimes block the intake. DOH!
