View Full Version : Sale on TOTO Vespin and Carolina toilets
08-07-2011, 01:07 PM
I have some Toto Vespin and Toto Carolina toilets on sale.
The Carolina is in Beige/Biscuit MS884114-12 (http://www.easycarts.net/ecarts/terrylove/Toto_Toilets.html#MS884114-12); I have two of these.
These are low tank, skirted bowls and come with a soft close seat.
The normal retail is $1,018.00, I Have them for $448.00
http://www.easycarts.net/ecarts/terrylove/images/ms884114_main
I also have the Toto Vespin 1.6 gallon.
I have one in Colonial White CST764SG-11 (http://www.easycarts.net/ecarts/terrylove/Toto_Toilets.html#CST764SG), Retail $598.00, my price $299.99
SS114-11 seat, $45.00
I also have one in Biege/Biscuit CST764SG-12 (http://www.easycarts.net/ecarts/terrylove/Toto_Toilets.html#CST764SG), Retail $688.00, my price $299.99
SS114-12 seat, $49.00
http://www.easycarts.net/ecarts/terrylove/images/cst764sg_main
These can be picked up in Bothell WA, or installed in the Seattle area.
treegirl
08-11-2011, 12:46 PM
I've been mulling these over for a bit (but I want white :)).. could you please explain what power gravity is? Can't find the explanation on the Toto site :) thanks
jadnashua
08-11-2011, 02:23 PM
There are generally two ways to provide the oomph to flush a toilet: gravity (the tank is higher than the bowl), or pressure assisted (the water pressure stores water in a bladder so it gets assisted by that pressure when you flush). There is another way, but it requires quite large water supply pipes - often used in commercial buildings. They rely on a really large volume of water being released in a very short time available from those large pipes (generally at least 1"). Toto uses gravity for all of its toilets except for a couple of the really high end ones that (I think) use a pump.
08-11-2011, 03:01 PM
Both G-Max and Power Gravity use a 3" flush valve and similar trapway.
G-Max has a higher water level in the tank, and a quick closing Red flapper.
Power gravity has a lower water level in the tank, and a slower Blue flapper.
I've used with one with success.
The Eco tanks use a Red flapper that is weighted down. That closes even quicker.
I sell the above toilets in Cotton White too, but I don't have the screaming pricing on those.
