Gannet1
GANNET1
Massachusetts
Hi all,
New to all of this,but here i am, I need to remodel a relatively small bathroom and would like some advice on where to purchase good plumbing parts online? I have found Home Depot and Lowe's to not really understand the things I am looking for. I have an older tub in very good condition, but the drain needs to be replaced, (there is a small hole in the pipe behind the top part that operates the tub drain, and there is a leak under the "shoe" that drains the tub.) It looks like brass piping from what i can see from the ceiling below, but very corroded. I would like to replace the tub drain and over floe with the same parts ,or better, but not sure where to find them. I cannot find a manufacturers name anywhere on the parts.
Thank you
Rebbeca
You'll probably have better luck replacing the whole drain assembly than individual parts.
