Will waterproofing fix this outdoor stairs problem?
alanrudy
longbeach, NY
Hello,
I have a house built above a garage and a small living area. I have a problem with 4 of the outdoor stairs leaking into a downstairs living area and I am getting conflicting reports from two contractors. One contractor, who I thought I could trust more, is saying if he waterproofs the stairs, the issue will be fixed and I should never have this issue again. Another wants to do a quick fix with some kind of concrete mix and says the same issue can/will come up in a few years because the stairs are built separate than the foundation of the house (which is true) and because of that and what he sees, the stairs will continue to move and cause the cracks that are causing the leaking. Attached are pictures: Pictures of Alburtis 005.jpgPictures of Alburtis 007.jpgPictures of Alburtis 011.jpgPictures of Alburtis 003.jpgPictures of Alburtis 004.jpg What do you guys think? Also, is there any work that should be done to the underside of the stairs or does everything look good there besides cleaning
the mold? Also, I don't know if this is completely out of the question, but is there anything else that I could put on the stairs, like a thin rubber pad, that would solve the water problem as well as make it quieter when someone is walking up the stairs for people living in the area on the first floor? Thanks so much in advance for any help on this issue.
Are you saying that the top of the stairs is exposed to the elements and there is living space directly below them?
If so, then in fact the stairs are a ROOF and need to be built to the same standards as any other ROOF. Slathering
goop on top of the treads (as it seems has already been done) is pretty much a waste of money. The goop-sellers
and the goop-appliers will of course have a different opinion.
I agree, these are wood stairs
They will always leak some, it can be minimized but there will always be some issue with these. Generally there is a storage area under the steps and maybe a plastic sheet to keep from damaging anything under them..
If you use plastic try and ensure air flow at the top and bottom.
Thanks for the responses. It is in California in an area with no snow/ice and not much rain either, but it looks like when it does, this will continue to be a problem unless something is done. Would something like this be a permanent solution...http://tinyurl.com/Rubber-Tread-Stairs Or would water somehow get under this product and through the cracks?
I think that the expansion and contraction of the wood would require something other than RedGard (which IS a good product, but I don't think for this application). Most membranes are not designed to be walked on, at least on a regular basis. If you wanted to tile it, there would be ways to waterproof it. It would require capping things with plywood first, though, since as mentioned, the solid wood planks just move too much. Look at www.schluter.com for some ideas. Noble and other companies make stuff that would work under tile, but tile would probably make the sound transmission worse, not better. Tile by itself won't fix the water issue, but there are methods to resolve that, then cover that waterproofing with tile for durability.
You could build a waterproof 'roof' underneath the stairway, which probably would be alot less expensive (if you have the room and somewhere to divert the water that gets through).
