View Full Version : Bends in horizontal drain line
Mikey
11-10-2005, 04:21 AM
Is there a convention/code/rule for the number of bends allowed in a horizontal waste line? I'm relocating a toilet to a location that will require a 90 degree bend (long sweep) into the 3" drain about 3 feet from the closet bend. I would prefer a 45 degree bend, but that would require demolishing a few square feet of finished ceramic tile floor. Either way, there's about another 60 feet of drain before the final (assumed) 90 degree bend to exit the house into the septic system.
11-10-2005, 05:14 AM
There is no stated "maximum" other than after a given number of degrees of turns you have to install a cleanout.
Oliver
11-10-2005, 01:47 PM
After 135 degrees of bends you need to install a clean out (UPCode)
Mikey
11-10-2005, 02:09 PM
The closet bend is 90 degrees, then there's a 90 degree sweep to the left into the main drain line, which already has a cleanout in it. Does this mean the stuff is in violation 46 degrees into the sweep? Wouldn't seem so, since it's a similar configuration to a closet bend into a vertical stack -- 90 + 90 -- which is pretty common. It would almost seem that the closet bend shouldn't count at all. Is the complete UPCode available on-line somewhere? I've got a condensed field inspector's guide, but it's not terribly clear in many areas.
