Shallow Well Jet Pump Venturi and Nozzle
srmcclur
Vermont
Hey. I have a new Dayton convertible jet pump with a shallow well bolt on ejector that I'm installing for a lake house. It's just drawing water from a hose from the lake only about 6 feet in depth and 100' of run.
I bought the shallow well ejector set and it has a variety of venturis and nozzles. It's apparent how the venturi screws into the ejector but there really aren't any directions and I can't figure out how the nozzle installs into the pump/ejector in relation to the venturi.
Sorry for the stupid DIY question...any help is appreciated !
The venturi should screw into the bolt on jet assembly, then bolt the assembly to the pump. The 3 venturi's are for different depths vs. pressure. In your case it won't matter much. I'd use the venturi with the largest inside diameter.
