bhpeart
Mech. Engineer
This is a perplexing problem. I have a sewage pit in the basement for the whole house. In the pit are two ejector pumps, Hydromatic SK100's. They pump through a 2" pvc pipe to the city sewer main with a lift of about 25 feet. Only one pump runs at a time and they alternate.
Everything was fine for 12 years. They never missed a beat. Then, after a week of vacation this year the pumps would run, but not pump out. I could only get them to work by loosening the union between the check valve and the pump and letting trapped air out.
So I bought a new Grundfos SE75 (this pump has a vortex impellar) because the parts for the Hydromatics were so expensive. I assumed the old pumps had eroded housings and impellars and could not build enough head.
Well the new pump does the same thing as the old ones. I still have to loosen the union to bleed the air.
I put an accurate gage on the outlet and when the flow is going I see about 12.5 psi. When the pump is off, about 8.5 psi. These pressures are very consistant and stable, so I don't think there is a clog. The gage is about 6' above the pump suction.
Next, I am planning to open the pit cover and drill a small hole in the pipe to vent the air, but I still don't know why the old pumps worked for 12 years without the hole and now nothing seems to work.
Any advice would be appreciated.
Thanks.
Thanks.
