GregN31
11-08-2005, 09:17 AM
Hello,
I recently discovered water pooling on the floor below the relief valve on the water heater. It appeared to have a slow drip at the time, so I had a plumber out who replaced the valve with a brand new one. To watch for any further problems, I put a bucket under the discharge pipe for the relief valve.
Intermittently, I'm finding somewhere about 1-2 cups of water in the bucket. I empty it and put it back and hours later I find another few cups. The valve is NOT leaking constantly, it appears to be firing occasionally apparently.
The water heater is 5 years old. The plumber checked the pressure at my water meter and at that time it was 80 PSI. I think I must have a backflow preventer, although I don't see it (but then again I'm not 100% sure what it should look like) because I'm quite certain the city code requires it. The code says:
"The City of Sioux Falls potable water system shall be protected from all
cross connections by a backflow prevention assembly in accordance with the City of Sioux Falls Plumbing Code and approved by the City of Sioux Falls Engineering Division."
From my understanding a "cross connection" would be my house and their city water at the water meter I guess.
By the way, turning down the temperature setting on the water heater appears to make no difference.
What is the most logical cause? Could it be that there is a spike in pressure from the city occasionally? Would a expansion tank on the cold water line going into the water heater be a good idea? Is 80 PSI an acceptable value?
I can catch the water in the bucket, as long as the volume doesn't increase or frequency doesn't increase, but that doesn't address the root cause.
Ideas?
Thanks,
Greg
Ideas?
Thanks,
Greg
