View Full Version : Toro Jar Top Solenoid Valve Installation
Hello: Great site with lots of good info! :)
We moved into a house with a Toro irrigation system. The valves installed are Toro jar top inline valves (53708) (see attached picture). Is there a trick to installing the solenoid. It screws in fine if I take out the solenoid plunger, but with the plunger in, the threads just don't make contact.
mike1059
07-04-2011, 11:53 PM
It takes a little downward pressure to engage the threads because of the spring. Just be persistent and careful not to cross-thread the solenoid and you will get it in time. I know it's frustrating at times but almost all solenoids have the same trouble.
BobL43
07-05-2011, 06:25 AM
K11,
I use the same valves in part of my system, and I have found that the plunger must be the exact type as belongs in that valve or else the threads won't engage. something with the length of the plunger I guess. I am not an irrigation tech, but over the years I have installed and replaced lots of Genie, and Toro valves and have gained lots of frustration and experience with them. I can't argue with a pro, but I am just posting from my experience. Any brand new toro Jartop valve I ever opened and re-assembled without losing or mixing up parts always went back together for me with no problem at all.
I tried it again this morning and I still can't seem to get the threads to meet. The plunger is the original one that came out of the solenoid and I checked a good valve to make sure I was installing the parts correctly. (Had no problem re-installing the good one.):confused:
Is it possible that the solenoid is U/S? The system was working fine last year, but when I tried turning it on in the spring some were leaking, and I noticed they looked like they were slightly pushed out and seem to be cross threaded.
BobL43
07-05-2011, 08:27 AM
Then I guess they were not properly drained/winterized and ice damaged them. Normally, though, the valve body would crack, but it depends on where there was remaining water.
We did blow out the system, but I think that the compressor we had may have been under powered for the job. I will try getting new solenoids and see how that goes. Thanks for the help!
mike1059
07-06-2011, 06:20 PM
I just had to replace a solenoid in an older model toro jar-top valve today and found that the right one is the toro 89-0114. Although the toro catalog says a universal solenoid will work the book is wrong. I think this could be why your having problems getting the new solenoid to seat.
The weird thing is that it is not a new solenoid. It's the same one that was in the valve last year when the system was working. I checked out the toro 89-0114, it looks a bit different than the one I have. Here are some pics.
134681346913470
mike1059
07-06-2011, 11:16 PM
Did you try instaling it with or without the white plunger cap. My experiance with the universal solenoids is to instal them without this cap.
I will try installing it without the cap tomorrow. Right now it's dark and I will get eaten by mosquitoes. What is the cap suppose to do? They seem to break apart very easily.
mike1059
07-07-2011, 12:47 AM
I belive it's just to hold the plunger in place during storage and transport before instalation. That's why I like rain birds encapsilated solenoid, no loose parts.
Just thought I would give a little update on my problem.
I finally got new solenoids and they installed easily. The old ones must have been damaged from freezing over the winter. (Will have to get a better compressor and do it right next time.) I had some valves that were stuck in the open position. From what I read, the Toro jar top valves are very sensitive to debris, so I took a bucket of water out with me, took them apart, and washed them. I had to wash one a couple times, but I did end up getting them to work properly.
briankeating
08-24-2011, 03:32 AM
You will have to consider getting new solenoid valves or you can also try the Pneumatic Solenoid Valves (http://apengr.com/). Either of them should solve the issue.
