View Full Version : St. elbow
Ed from chicago
06-27-2011, 05:35 AM
Hi Guys!
I have another odd question for you. Can you tell me why the male end of a 1/2" st. elbow has a smaller i.d. than a 1/2" pipe?
Thanks
06-27-2011, 05:46 AM
It is a malleable cast fitting so the wall thickness has to be greater than piece of steel pipe. If it is a machined or forged fitting, the wall can be thinner.
Ed from chicago
06-27-2011, 06:33 AM
Thanks hj, the reason i ask is because i have a 1/2" st 90, that is located in bad position. I can't get a pipe wrench around the male end of the fitting, which is connected to a tee. The female end is sticking up, but i fear that putting a wrench on the other end could cause it to break, if i use a pipe wrench and a cheater bar.
Thanks
Ed from chicago
06-27-2011, 06:35 AM
I meant the female end.
06-28-2011, 06:12 AM
Street ells CAN snap off, which is one reason they are not allowed for gas piping, but I think you will be safe doing it in your case. They usually snap from "side impact" not twisting. In fact, if you have room, I would put a nipple into the elbow and use that to get it started unscrewing.
