View Full Version : Need help with drainage in back yard
Michael Rudd
06-21-2011, 03:26 PM
I wrapped concrete around the back of my house for decorative and drainage purposes, but on one side I cant figure out how to complete the drain. The pre-existing drain is higher than I can make the new drain to allow proper drainage when I tie into the existing drain. It would cost way too much time and money to completely redo the entire thing, so is there any ideas on how I can get the slope needed in the new line to allow it to drain into the old line? I could pour an extreme amount of concrete to get the height, but that would cause a lot of new problems. Thanks for your time.
mike1059
06-21-2011, 04:55 PM
First, do you know where the old line drains to and can you run the new line to a lower point on the old line. The other option is a dry well if you have a spot to put it.
MikeRudd
06-21-2011, 06:28 PM
The lower point in the existing line is not accessible due to a concrete floor. What exactly is a dry well?
mike1059
06-21-2011, 07:30 PM
A dry well is basicly a hole a couple of feet around and up to six feet deep and filled with drain rock to help disperse the water. The depth depends on how much water and how fast a dispersal you are looking for. The drain rock can also be coverd by filter paper topped by bark or 6" to 8" of soil and sod.
Smooky
06-21-2011, 08:06 PM
Have you thought about pump drainage?
