TY
11-04-2005, 10:40 PM
I'm adding a bathroom upstairs in my 1927 home in Ballard, Wa. The bath is going into the center of the house with a dormer and my stack goes up the side of the house. So, I plan to send a drain staight down and connect to one of the horizontal drains that goes from one end of the house into the stack at the other end. I plan to have a bathtub, toilet, separate shower and 2 sinks up there. I tried to attach a jpg of the layout. The dotted lines are floor joists.
So the questions are:
1) What size drain should I run down through the wall? I was planning a 3 inch pipe. Is that big enough for a toilet drain?
2) I'm restricted a bit by floor joists, but if I have my toilet go through the joist (draining forward rather than backwards) I can create a main drain pipe where the tub, toilet and shower all attach in run parallel to the joists and exit left down through a wall below. Is this OK? 3 inch pipe?
3) Venting seems like it would be a trick, since the whole thing would be in the floor. I could vent it on the one side of the main drain where the tub is, and then right above where the drain goes down...
