View Full Version : Life expectancy of copper and black iron pipe
luc
06-17-2011, 06:11 AM
Hello everyone,
We are doing some renovation on our hydonic heating system which is over 50 years old. The black iron pipe is in good condition. Just want to know if it is better to use copper pipe or black iron for our renovation. Which will have a longer life expectancy?
Thanks,
Luc
ballvalve
06-17-2011, 10:24 AM
Your black iron pipe is DUCTILE IRON pipe. Very good material. Gas line is junk. Do not make that mix up.
http://www.dipra.org/
http://www.vikinggroupinc.com/en/products/489/600
luc
06-17-2011, 11:42 AM
Thanks ballvalve for replying.
So it would be better to continue with the ductile iron pipe for our renovations rather then copper!!
Luc
jadnashua
06-17-2011, 02:06 PM
If you maintain the heating system so there are no leaks and you don't have to add water regularly, the iron pipe can last a very long time. It has problems when you introduce air into the system (by adding water - there is some gas disolved in the water). Copper works, too, but is more expensive, but easier to cut and work with. The iron pipe reacts with the O2 in side along with the moisture to rust out from inside. No O2, no rust.
luc
06-18-2011, 10:50 AM
Thanks jadnashua and ballvalve for the replies. It answers my questions.
