View Full Version : Teflon on supply lines
MikeG
11-04-2005, 06:46 PM
I'm installing a Jado faucet in our bathroom. It has a separate spout and valves. The valves and spout are connected with braided lines and the male ends on the valves and spout are flat. There is a fiber or rubber washer in the supply lines. Should I wrap the threads with teflon tape or use any type of thread compound? Will the teflon interfere with the connection?
Also, the supply lines from the hot/cold shutoff valves are braided lines as well. The male ends on the valve stems are not flat on these. Should I use teflon on the threads?
Thanks, Mike
jeffreyhel
11-04-2005, 06:55 PM
Generally speaking if there are fiber or rubber or "O" rings then no tape is necessary. Even with a flaired compression type if the joints were properly ground when manufactured then you shouldn't need anything but I would put just a dab of teflon dope on the ends and call it a day.
11-05-2005, 12:36 AM
Don't put anything on the threads.
MikeG
11-05-2005, 04:51 AM
Thanks guys for the response! :)
