Peerless kitchen faucet leaking at base of spout!!!
Nards01
Washington County, PA
I have an older model (model # unknown) Peerless two handle faucet that is leaking at the base of the the spout. I assume that the o-rings need replaced. But, there is a cap on the top of the spout neck that appears to screw off so that you can remove the spout to get to the o-rings. I tried using a monkey wrench but it won't loosen. I'm afraid of turning it too hard for fear of damaging it. Is it possible that it is a reverse thread?? Any suggestions - I'd appreciate it. Also, if you are familiar with this unit maybe you can provide me with model number. THANK YOU in advance for any help.
HJ - thanks for your response. One other question - if I attempt to unscrew the cap will too much pressure cause damage. Is cranking a monkey wrench on it about the only way to get the cap off??
