TWS
greetings pump forum,
i am ready at long last to install a pump and pressure tank for my ten foot deep well - 24" shaft. tho this spring has been very wet today the well is full at approx 7' of it's 10' depth.
i am looking at a lowes store Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump and a well saver 20 gallon pump tank - horizontal profile.
i don't know anything about wells or pumps and pressure tanks. i do know that i would like to use 115 volts instead of 220 if at all possible... moreover i do not know how fast the well water is replaced especially in late dry summer... the well is in my garage and i just finished casting in place a 500 lb cement well top 29" tall by 30" in diameter. the well head stands approx 5 feet from the exterior wall of my garage and i intend to frame in this cement culvert thus creating an interior space for the pump and horizontal 20 gallon pressure tank covering the lot with a piano hinged table top to access the well and machinery. the finished result will be a handsome desk top hiding a perfectly serviceable well. naturally i'll be plumbing the pump and pressure tank lines/hoses thingys to fit a faucet that will extrude from the garage wall to the outside garden area.
can i trust the utilitech brand of pump? given the well's dimensions will a 3/4 hp jet pump be adequate and will a 20 gallon pressure tank suffice? this is for garden watering exclusively. what brand of pump/pressure tank would be advisable if the lowes brand is marginal?
attached are images that i hope will illustrate my situation.
all advise is welcome.
thanks,
tws
thanks,
tws
