Help with PEX pipe sizing
LesP
PNW
Hoping you smart folks can help me plan my plumbing upgrade correctly. I am planning to use Uponor Wirsbo PEX and EP (plastic) fittings.
I have attached a diagram of the remodeled kitchen, laundry, and hose bib that will need new supply lines. The line currently supplying the whole house is 3/4" galvanized steel and the fixture branches (everything past the water heater) are 1/2".
Eventually I will be swapping out all the galvanized pipe for PEX but for now I am just working on the kitchen and laundry. Should the new PEX trunks be 3/4" reducing down to 1/2" at the Tee supplying the fixture? Or should I just use 1/2" pipe throughout?
These lines will be running in the floor joist bays so I will have to make both horizontal and vertical turns. When is it appropriate to bend the PEX and when is it necessary to install an elbow?
At the fixture, is it better to use a copper stub ell or the Wirsbo drop ear bend support? (I don't have much experience sweating copper!)
Thanks in advance for your help!
Each type of tubing will list the minimum radius bend it can support. The larger the tubing, the larger the radius. Usually, the bend supports will provide you with a neater corner at about the minimum radius without kinking. One of the beauties of pex is that it does bend, and you can minimize the fittings required. So, go with that. They do make preformed stubouts with a pex fitting, so no soldering required. It does work best if you use the support bars, and the stubout is soldered to that. Makes for a neat, strong supply for your shutoffs and supplies to the fixture.
PEX plan
Thanks for the quick input. Here's my new plan, with more details. Please let me know if I have the pipe size and fittings right. FYI: the distance to the furthest fixture is about 30 ft away.
I thought about using Uponor's remote manifolds but for so few fixtures it didn't seem to be helpful. Any thoughts to the contrary?
