View Full Version : Drain Cleaning Tips!
sjson
05-10-2011, 12:32 PM
You notice the water level in your sink isn't going down. If it is, it's descending at a snail pace. Rather than reaching under the sink for a bottle of Drano, try these tips to ensure a happy sink and ultimately, a happy YOU.
1. Identify what's causing the clog. If you think the likely verdict is hair, you can simply get a drain stick with barbs in it to retrieve all the hair. If it's something else, it will be extremely useful to identify it to take a different plan of attack.
2. Stock up on a few simple tools. Purchase the aforementioned drain stick, barbed and smooth. A small wet/dry vacuum is nice to have in the kitchen closet and of course the plunger.
3. Try to use natural ingredients-based solutions rather than harsh chemical products. A strong vinegar-lemon solution can do the trick for some basic clogs that have things stuck to the side.
4. Take apart the pipes and clean them out with a toothbrush or some sort of scrubbing pad. WARNING: Make sure you know what you're doing before dismantling the plumbing.
5. The best thing you can do to clean your drains is by preventing the clogs from the beginning. You can run a natural solution down the drain on a bi-weekly basis. You can purchase a strainer to prevent hair from entering the drain.
If you have any other suggestions or tips to add please chime in!
kzhen8
09-28-2011, 09:27 AM
Thanks for the tips! Don't believe in using Drano either or anything that is not natural.
10-01-2011, 08:10 AM
and when NONE of those "tricks" work, do what you should have in the beginning and call the plumber. FEW stoppages are close enough to eliminate with a "stick", and ANY chemical, natural or not, is ONLY going to make the smallest opening it needs to flow down the sewer.
dave36
04-17-2012, 01:24 PM
Get a simple manual drain snake, just in case something really gets clogged and a natural solution will not clear it out. It is simple to use and will remove the blockage.
ballvalve
04-17-2012, 01:42 PM
A garden hose with a tee shirt held tight around any pipe will open just about anything - or jet it into a long drain pipe.
