View Full Version : Radiator Valves
Ed from chicago
10-30-2005, 07:58 AM
Hi all!
Can you please discribe the difference between a steam radiator valve and one that controls the flow in a a hot water system. And whether they are interchangeable.
Ed
10-30-2005, 08:25 PM
A steam valve is a globe valve with a fiber disc washer and it closes by turning the handle until it stops. It turns off the steam completely or you would have condensation problems in the radiator. A hot water valve turns off by rotating a cylinder to close the opening. The cylinder has a small hole in it to allow a minimal amount of water to flow through the radiator. A steam valve can be used for hot water, but a hot water valve cannot be used for steam.
