View Full Version : Grout or Caulk at Tile corners?
scottl44
05-02-2011, 02:30 PM
Hello,
In my last house (tract built 2002), the contractor caulked the joint where the side wall tiles meet the back wall tiles in the stall shower.
In my new (1956 fixer) house, the contractor I hired used grout in those corners. We have 13" tiles, 1/16" joint non-sanded.
It seems the grout near the bottom on one side likes to crack. I fill the cracking, but it comes out again. Probably not sticking to the sealer.
ANYWAY, what say you all? Grout or caulk where the side walls meet the back wall?
If you say caulk, I guess I should strip out that grout in the corners. But should I cut out some of the caulk where the tiles meet the pan to make sure no water got in?
The shower pan is a 30" square Florestone with those 1" channels at both sides of the front. Those are open, but the gap between the tile and pan is caulked with silicone all the way around from one of those channels to the other.
I have read some opinion that some gaps should be left in a few places in that caulk to allow wayward water to escape. If that happens, then it may get in at a spot where there is no gap. So why not just leave the whole thing uncaulked where the tile meets the pan?
If anybody could set me straight, I'd appreciate it. Thanks!
Scott
LLigetfa
05-02-2011, 05:06 PM
If you have movement at the corner, you have no choice but to caulk. Around the base, there is the potential for movement so again, caulk is called for. As for a place for water to weep, it can do that at the grout joints just above the caulk.
When I redid my shower, I used lots of deck screws to lock the framing at the corner to prevent movement. I also used the heavy fibreglass mesh tape on the modified mortar joint of the concrete backer and the corner got a double layer of KERDI where it overlapped at the corner. The tiles met evenly at the corner rather than one tile going behind the other. I grouted the corner and there has been no movement what so ever.
dlarrivee
05-02-2011, 06:43 PM
Caulk at any change of plane.
jadnashua
05-06-2011, 09:15 AM
This is the industry standard as called out in the Tile Council of North American handbook (the industry bible). Now, if you are lucky, you may get by with grouting it. There are color-matched sanded and unsanded caulks for most grouts.
k9mlxj
05-06-2011, 12:26 PM
Hi, I have a similar situation (see photo). I'm seeing a gap (crack along existing grout) where the wall tiles meet the pan (floor tiles) in the shower. Thought would just join in instead of starting new thread.
My question is,
Do I just leave the gap alone and caulk over existing grout w/ silicone? Or remove the existing grout along the edges where the wall tiles meet the pan before putting the caulking in? Any merit to leave the existing grout around?
Thx.
jadnashua
05-06-2011, 12:29 PM
Pull the grout (may need a grout removal tool or a knife) and caulk. Depending on what you use, you may have to do this periodically. www.johnbridge.com (http://www.johnbridge.com) is a good source of info on tiling issues.
scottl44
05-11-2011, 10:21 AM
OK, got it on the change of plane. Strip the grout and caulk it. Thanks!
But what about what I read about leaving gaps in the caulk where the tile meets the pan? If that's recommended, then why not leave it uncaulked altogether?
johnfrwhipple
05-11-2011, 09:21 PM
Post(s) deleted by John Whipple
scottl44
05-19-2011, 03:56 PM
That wasn't my picture. My question was the original one. The first one got answered, but the second one about leaving gaps in the caulk where the tile meets the pan, 2 posts up, did not.
Anybody have an opinion? Thanks!
LLigetfa
05-19-2011, 04:08 PM
That wasn't my picture.The way this board assigns people the same avatar can get confusing about who's who.
I thought I answered your question. I would not leave any gap. The vertical grout lines above the caulk will provide all the weeping that is needed
jadnashua
05-19-2011, 06:07 PM
A properly built shower should not allow liquid water behind the tile. Any moisture that wicks there should be able to evaporate through the grout lines and not build up. I'd not leave a gap anywhere. Grout sealer, at least most, does not prevent moisture from evaporating through the grout, if it did get wet.
kreemoweet
05-19-2011, 09:15 PM
In an otherwise correctly built tile installation, the choice of grout or caulk is largely a cosmetic issue. At changes of plane, or where dissimilar materials meet, the use of
unyielding grout will "usually" result in cracks. It will also "usually" look better. It is a fussy, difficult job to make caulk look good, and many talented tile setters are not inclined
to bother. The worst thing you could do is smear caulk on top of cracked grout. Leaving an unfilled joint would result in the accumulation of crud, which will soon turn black and
nasty.
scottl44
09-01-2012, 02:02 PM
After all this time, I find that the GE 100% silicone I used turns black in few spots and can't be cleaned.
I was reading elsewhere here that Terry (I think) was recommending polyseamseal around a toilet instead of silicone. Is that also a good choice for the shower where the tile meets the pan and where the tile changes plane at the corners?
Thanks,
Scott
nestork
09-01-2012, 11:13 PM
That "can't be cleaned" business isn't true.
Hang on, my computer keeps freezing for some reasno
nestork
09-01-2012, 11:24 PM
No, I own a small apartment block and I clean the mildew off the silicone caulk around my tubs after every tenant vacates. Sometimes, when you get three guys living in an apartment for several years, and they shower three times a day and NEVER use their ceiling fan, it can get to look pretty hopeless, but I find that I rarely ever have to replace any silicone caulk. I don't think I've actually replaced any silicone caulk (cuz I couldn't get it clean) in over 10 years now.
Read my post in the thread entitled "silicone caulk is not sticking to acrylic tub surface" in this forum (about a dozen below this one) and you'll have your silicone caulk white as Manitoba snow.
You definitely don't need to know the rest cuz it's really just chemistry trivia.
The reason they call it silicone caulk and not siloxane caulk (which is what it is) is because of a mistake chemists made when they first started trying to make plastics out of silicon.
Both silicon and carbon atoms form four covalent bonds, so, just as you have carbon dioxide (O=C=O) which turns out to be a gas, you can have silicone dioxide (O=Si=O) which turns out to form a white powder.
After the end of WWII, chemists started making carbon based plastics out of petroleum. So they naturally wondered if they couldn't also make similar plastics out of silicon because it formed the same number of covalent bonds as carbon. They discovered that in the silicon based plastics they did make, there were the same number of oxygen atoms as silicon atoms.
Now, at the time they knew that carbon based plastics formed molecules with long carbon chains, like this:
http://www.pslc.ws/mactest/images/pe02.gif
so they assumed that a silicon based plastics would do the same.
And, if you know that there's the same number of oxygen atoms as silicon atoms, you come up with a structure that looks like this:
Si=O
Si=O
Si=O
Si=O
Now, here's where I have to go off on a tangent....
A "ketone" is a class of chemical that has the general structure:
Something #1
C=O
Something #2
... where C is a carbon atom and O is an oxygen atom.
If both Somethings are methyl groups (-CH3) then you have di-methyl ketone, or "acetone" for short. If Something #1 is a methyl group (-CH3) and Something #2 is an ethyl group (-HCH-CH3), then you have methyl ethyl ketone, or MEK for short.
and here's where I come back from that tangent...
So, since chemists at the time thought that silicon based plastic was nothing but a long string of Si=O groups, they took the word "silicon" and added an "e" to the end to make it rhyme with "ketone" and thus coined the word "silicone".
So, it's Silicon Valley, but it's silicone caulk.
Now, it turned out that their "Si=O" structure for silicon based plastic was actually wrong. The real structure was more like this:
-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-Si-O-
, only with other stuff bonded to the silicon atoms, depending on what kind of silicon based plastic you have, like this:
http://4.bp.blogspot.com/-04-Vbrzo9hY/Tb6MWiO8f7I/AAAAAAAABBs/F6-EjrebMyQ/s1600/pdms.jpg
Where the "n" in that formula stands for any number of repeating "dimethyl siloxane" groups. That is, the ugly thing in the square brackets gets repeated over and over again, umpteen to umpteen dozen times in each silicone molecule.
Still, the mistake stuck, and the simplest form of silicon based plastic is still called "silicone" rubber today. However, the new "corrected" name for silicone is "siloxane", so if you see the phrase "anything siloxane", it means it's a silicon based plastic.
What you have around your bathtub is actually "poly di-methyl siloxane", or polydimethylsiloxane for short, just like in the picture above.
Ya gotta know this stuff to be king. It's part of my "How To Be King" correspondence course.
scottl44
09-02-2012, 12:09 AM
It takes more than 15 minutes to get the black stuff off?
nestork
09-02-2012, 01:54 AM
That black stuff is mildew. It's a fungus that feeds on the vegetable oils found in bar soaps, like the palm and olive oils from which the Palmolive company got it's name.
That's why you never see mildew growing on ceramic tiling above a bathtub in a house where people have baths instead of showers. It's the soap that gets deposited onto the walls in a shower that provides the food supply mildew needs to survive and multiply. When someone has a bath, neither soap nor soap scum will ever get more than an inch or two above the tub, and so you never see mildew on the grout in a house where people have baths instead of showers ('cept for an inch or two above the tub).
When I clean mildew off silicone caulk, I leave the Borax/Bleach slurry on for several days. However, I've found that most of the cleaning occurs within 24 hours. If you don't have another bathroom you can use to shower or take a bath, just cover the slurry with 2 inch wide painter's masking tape, and then cover that painter's masking tape with packaging tape to make for a moisture-proof seal.
Then shower normally and take the tape off in a few days. Then, remove the dried up borax/bleach slurry with a putty knife (being careful not to harm the underlying silicone caulk) and you should find that your silicone caulk is spotless. (That slurry won't have actually "dried"; it'll have solidified. The water in it gets bound up in the solidified stuff just like the H2O in the gypsum core of drywall.)
PS: Boron is a natural fungicide just like zinc and copper. In both zinc naphthalate and copper naphthalate wood preservatives, it's the zinc and copper that are the active ingredients. Boron is the active ingredient in borate wood preservatives like Tim-Bor and Borocol liquid wood preservatives as well as Impel and Cobra Rods which are also boron based. So, by mixing Borax into the bleach to make the slurry, you've got a natural fungicide in your slurry, thereby making it more effective at killing fungii than if you'd made the slurry using any other powder.
PS #2: I expect you could probably eliminate the possibility of mildew growing on your silicone (or anywhere) by using a skin cleanser that didn't have any vegetable oils in it, like either Cetaphil or Aquanil, both of which are available at most drug stores. Both Cetaphil and Aquanil advertise themselves as being "lipid free", and that's just means they don't contain any "fatty acids" which is what vegetable oils and bar soaps are made of. And, it's those lipids that mildew eats to survive and multiply. So, by switching from using a bar soap to a "lipid free" skin cleanser in your shower, I'll bet dollars to donuts that you won't ever have any mildew anywhere in your shower. That is, by using a lipid free skin cleanser, you deprive the mildew in your shower of food, and whatever mildew is inside your shower slowly starves to death.
http://2.bp.blogspot.com/_CVf9NbFtrKE/TMboicEMmeI/AAAAAAAABEk/4kZqjcx6tFc/s1600/1532.jpg
http://2.bp.blogspot.com/_PzfDlHktJqQ/S6zCHkhN4nI/AAAAAAAAAa4/LdIrf2Lsh9Q/s1600/cetaphil.jpg
So, you could clean the mildew off your silicone caulk with a borax/bleach slurry or switch to a lipid-free skin cleanser and wait for nature to take it's course. Or, do both and prove to yourself that the mildew doesn't return as long as you're not feeding the mildew in your shower with fatty acids from the bar soap you're using.
Ya gotta know this stuff to be worth your salt as a janitor.
scottl44
09-02-2012, 10:46 AM
Fantastic. I had no idea. Just a couple more questions.
Since the soap goes all over the shower and not just on the caulk, why doesn't it grow on the tile or the grout? It does seem to get on parts of the metal door frame though.
I have a steel sink in my kitchen with clear caulking where it meets the granite counter top. Some of that same black discoloration is in the clear caulk and I've rarely, if ever got any soap in these areas. Any ideas here? Will the bleach/borax work on this too?
Are there any bar soaps that don't have the fatty acids?
nestork
09-02-2012, 05:11 PM
For some reason, every time I post, the post ends up being posted twice.
This was exactly the same as the following post before I changed it to a two sentance post.
nestork
09-02-2012, 05:33 PM
To answer this part of the question, you need to know that there are two kinds of grout; epoxy grout and cement based grouts. Epoxy grouts are impermeable plastics and never need to be sealed to prevent mildew from growing on them. Cement based grouts (both sanded and unsanded) dry porous and need to be sealed to prevent mildew growing on them. So, if you have epoxy grout, you'll never need to worry about mildew growing on your grout, and so the rest of this post will confine itself to cement based grouts.
In a nutshell, the reason why there's no mildew growing on your grout yet is because it's still too alkaline, and therefore not to the mildew fungii's liking. But that will change with time as described below:
There is a cycle in nature called the "Lime Cycle" and it's important for every DIY'er to know and understand that cycle and how it affects masonary products, like concrete, concrete blocks, brick mortar and cement based ceramic tile grouts.
Here is the "Lime Cycle":
http://www.graymont.com/images/products/what_is_lime_diagram2.gif
Marble is nothing more than limestone that's been compressed by the weight of the Earth's crust or oceans and heated by geothermal heat. So, when Rome fell, Roman citizens pulled the marble off the walls of the Colloseum and other public buildings and burned it in fires to make a white powder called "quick lime" or "calcium oxide" (formula: CaO). When you mix quick lime with water, you get a slurry called either "slaked lime", and if you let that slurry dry to a powder you have "hydrated lime" or "calcium hydroxide" formula: HO-Ca-OH, which is the "lime" we mix with portland cement and aggregate to make concrete mix in bags. We also mix that lime with portland cement and sand to make brick mortar. We mix that lime with white cement and sand (or not) to make unsanded and sanded ceramic tiling grouts and we mix that lime with Plaster of Paris to make real lime based plasters for the interior walls in older homes.
But, take a look at the formula for hydrated lime powder: It's HO-Ca-OH, and it's those hydroxyl groups (-OH) that makes the lime highly alkaline. So, when you mix hydrated lime with porland cement, sand and/or Plaster of Paris (which is gypsum), the slurry you get is highly alkaline, and as it solidifies it remains alkaline... for anywhere from about a year to two years.
During that first two years the alkalinity of fresh concrete, brick mortar, lime plaster and ceramic tile grout will diminish as the CO2 in the air reacts with the hydrated lime to form calcium carbonate, which is the principle constituent of limestone, like this:
HO-Ca-OH + CO2 makes CaCO3 plus an H2O molecule (which turns into a butter fly and flies away).
So, the lime added to your ceramic tile grout when it was manufactured is gradually turning into limestone, and as it does those hydroxyl (-OH) groups in the grout disappear and the alkalinity of the grout subsides.
How that affects you as a DIY'er is that you have to be careful painting fresh concrete or concrete blocks because if you use an oil based paint, the fatty acids in the oil will react with the high alkalinity of the concrete to convert the oil based paint into a crude form of soap, and the result will be that the paint will disintegrate on the fresh concrete, concrete blocks or lime based plaster. That reaction is called "saponification", and all soaps are made by using that saponification reaction to convert animal or vegetable fatty acids into soap in the presence of a strong alkali.
aside (If you have to paint fresh concrete, you can use a special acrylic primer made for this purpose on it after only a month or two, and then paint over that primer with any paint you want. The primer effectively acts as a physical barrier between the highly alkaline concrete and the top coat of paint. Once concrete, concrete blocks, brick mortar and the like are more than 3 or 4 years old, their alkalinity will have subsided sufficiently that you can paint them with anything without concern about alkalinity being an issue.)
In the case of your bathroom walls, THE ONLY reason mildew isn't already growing on your grout is that it's still too alkaline for mildew's liking. As the alkalinity of your grout diminishes, you'll find more and more mildew starting to grow on it, and in time you could be looking at something like this:
http://www.allsurfacerenew.com/blog/wp-content/uploads/2011/06/mildewed-grout.jpg
Mildew won't grow on the surface of wall tiles because ceramic wall tiles are glazed, and so the smooth glazed surface of the tiles prevents the mildew spores from grabbing onto anything to anchor themselves in place. Basically, they get water cannoned off the glazed wall tiles by the water spray and end up going down your shower drain. Porous grout, on the other hand, is a mildew spore's idea of heaven. It has a strong porous surface that mildew fungii can root itself into well, and a continuous supply of food every morning and many friday and saturday evenings.
Bar soaps are most commonly made by combining vegetable oils with sodium hydroxide (formula: NaOH), also called "oven cleaner". If you use potassium hydroxide instead of sodium hydroxide, you tend to get liquid soaps like skin cleansers. To mildew, it doesn't matter what kind of soap it is, as long as it's got fatty acids in it, it's food. It's very possible that you have some liquid soaps on your bathroom vanity that may have gotten onto that caulk.
My experience has been that the less time mildew has grown in an area, the easier it is to remove with a borax bleach slurry.
I very much doubt that bleach would harm your granite. Bleach works by releasing lone oxygen atoms, and those lone oxygen atoms react with anything unstable enough to react with them, and those tend to be things that would decompose on their own given time, such as large organic molecules. The stuff in granite won't decompose on it's own no matter how much time you give it, so I expect any kind of natural stone is too stable to be affected by bleach. I'd say that the bleach/borax slurry would work equally well on the clear caulk around your sink, too. If it turns out that it doesn't, it's not hard to remove caulk and replace it. It's just that with silicone caulk, you need to remove it completely before the new silicone will stick.
I would say that every bar soap will be made of vegetable oils (and in rare cases, animal fats) and so every bar soap will contain fatty acids.
The difference between a detergent and a soap is that a detergent is a synthetic soap. It's made out of chemicals, but it's works the same way as soap to emulsifying soils in water. The advantage to detergents is that they can be formulated to avoid a lot of problems inherent in soaps. For example, the reason you never see a soap scum ring in your KITCHEN sink is because you don't use bar soaps in your kitchen sink. You use dish washing detergents in the kitchen sink that can be formulated to either not react with the hardness ions in water, or to not lose their solubility in water even if they do react with the hardness ions.
So, if environmentalists use Dawn dish washing detergent to clean the crude oil off ducks and pelicans after an oil spill, I'd say it'd be worth a try using Dawn dish washing detergent in your shower to at least avoid getting soap scum all over your walls, and hopefully deny food to the mildew spores in your shower.
I don't know whether there's any vegetable oils in Dawn, so I'd trust a skin cleanser that advertised that it was lipid free to deny mildew a source of food before I'd trust a dish washing detergent to do that.
PS:
You can learn an awful lot about the chemistry of cleaning at the American Cleaning Institute's web site (formerly called the American Soap and Detergent Manufacturer's Association) at:
http://www.cleaninginstitute.org/
scottl44
09-02-2012, 05:37 PM
Thanks so much for your detailed answers!
nestork
09-02-2012, 06:22 PM
Also, if you want to know how bleach actually works to kill mildew, read this post I wrote on a DIY forum I used to post on:
http://www.homerepairforum.com/forum/everything-else/11110-vertical-fan-ions.html
I own a small apartment block and so I have to know about this stuff to protect my investment. My business wouldn't be nearly as successful and I wouldn't be able to attract desireable tenants if my bathrooms looked like the one pictured above.
scottl44
09-12-2013, 11:24 AM
Hi guys,
Back again.
Now that my little girls are getting bigger, they want to start taking showers, so I need to install a sliding door over the tub.
Anyway, the same contractor used grout in the corners of that shower and it's cracking so I'm going to strip it out and caulk the corners.
My question is which caulk to use? I tried some GE silicone in the other shower but it seems like it gets black mildew within a year or two.
I found this DAP Silicone Plus Premium Silicone Rubber Sealant
Can anybody let me know if this is a good choice to use for all my change of plane joints, or is there something better?
Thanks a lot,
Scott
johnfrwhipple
09-13-2013, 06:12 AM
scottl44
09-13-2013, 06:29 AM
If it was moisture from behind, wouldn't the caulk be discolored all the way through? I can dig or scrape at this stuff and see the caulk color underneath.
Which shower do you mean, the one that's done or the one I want to do?
scottl44
12-17-2013, 09:14 AM
I have gotten used to putting sealer on grout, but I never actually knew why.
Is it to keep water out, or to keep the grout from staining?
Thanks,
Scott
jadnashua
12-17-2013, 12:17 PM
Grout (and it helps on some tile as well) sealer is primarily for helping to prevent stains. While it may have a short-term water beading capability, it is not a filler that prevents water from migrating through the surface. A typical glazed tile doesn't benefit, nor does a straight porcelain tile unless it is polished, then the pores are opened up, and it should be sealed as well as the grout. A urethane and epoxy based grout typically does not benefit from sealing, only cement based ones.
John Bridge
12-17-2013, 04:29 PM
Mold behind silicone only means the silicone should have been replaced before the water got behind it. It's not permanent material. Remove the silicone, allow the joint to dry out thoroughly, and then install new silicone. :)
scottl44
12-17-2013, 04:42 PM
I just have Custom's non-sanded in 1/16" joints.
I always had thought sealer was to keep out water. So is it normal and permissible to have water leech in to those joints? It doesn't cause any water damage inside the wall?
jadnashua
12-17-2013, 08:26 PM
A properly built shower isn't damaged by moisture even before the tile is installed. Except maybe in a commercial shower or steamroom, the shower is not typically used more than an hour or two each day, so it has time to dry out. Sealer is primarily designed to help prevent staining, but it does help slow, but not stop, moisture. On a conventional shower pan build, they put weep holes underneath the tile for a reason...gravity helps move any moisture that does get there down the sloped liner and out the drain. ON a wall, it primarily dries to the outside.
The reason I prefer a surface applied membrane is that there is so much less in a shower that can get wet in the first place on both the walls and the pan, so it will dry out much faster than a conventional shower built over materials that can absorb moisture, and, I feel, is a much better solution to a shower that gets heavy use.
johnfrwhipple
12-18-2013, 05:38 AM
scottl44
12-22-2013, 09:13 AM
OK, are you saying that any water that gets through the grout will just come back through? Since this 30x30 stall shower is caulked on three sides where the 13" tiles meet the pan, the only "drain" holes are on either side at the front. I was reading on another tile forum that it is recommended to leave gaps in a few places in the caulk to allow for the drainage of any water that gets in. But where and how far apart to make those gaps; maybe at each grout line?
John Bridge
12-22-2013, 12:01 PM
Scott,
You won't find anything in prevailing standards that specifies "drain holes." Neither will you find and\y reference in the Handbook for Tile Installation put our by the Tile Council of North America. :)
scottl44
12-22-2013, 12:50 PM
Scott,
John,
Not sure I understand your answer. The drain holes I mention are maybe called weep holes, but they are part of the Florestone pan I mentioned, so they may have nothing to do with tile.
johnfrwhipple
12-24-2013, 06:49 AM
scottl44
01-11-2014, 09:43 AM
OK, just so I can be clear, it is normal for water to get through the grout, and it just evaporates or seeps back out. Is that correct?
Also, should there or should there not be any gaps left in the caulking where the tile meets the shower pan? (30" stall shower caulked on three sides where the tile meets the pan at the bottom.)
jadnashua
01-11-2014, 05:08 PM
Neither the tile nor the grout is totally waterproof, and therefore, yes, you will get some moisture to penetrate, especially when hit with the shower spray directly. Now, how far in, or how much will depend on how often the shower is used and the type of tile and grout, and the quantity and pressure from the head(s). How quickly the shower dries out can be a factor - the dry desert verses the FL coast, and how well the ventilation is done (often, how long the fan is left on, or if the doors or curtain are left open).
There is no industry standard for your second question. Some like to leave gaps to make it easier for moisture to escape, some ignore that entirely. If the shower is built properly, it won't matter, at least from a damage viewpoint. IF the grout lines are not huge, and the tile is either porcelain or glazed, very little moisture will penetrate, and most often, that that does, evaporates in between uses. It's more of an issue on the pan, and unless you use a surface membrane, the slope of the liner and the operation of the weepholes are the critical things.
eurob
01-11-2014, 05:49 PM
1. Yes , if cemetituous grouts are used .
2. No gaps in the silicone, nor I would ever leave some on showers or tub surrounds .
johnfrwhipple
01-12-2014, 06:19 AM
eurob
01-12-2014, 07:45 AM
The answer was directly to the above post . I did correct it -- NO Gaps In The Silicone -- .
Thanks for pointing it out . ;)
scottl44
01-26-2014, 09:16 AM
OK, it's 13" glazed porcelain tile with 1/16" non-sanded joints. I think it's on backer board AND "green" board behind that.
So John, are you saying yes to some gaps in the caulk where the tile meets the pan? If so, would they be best at the grout joints?
I got this recommendation from this thread, first paragraph, but could never get any definitive way it should be done:
http://www.johnbridge.com/vbulletin/showpost.php?p=1071160&postcount=139
eurob
01-26-2014, 10:44 AM
Not really sure where you are going with this , Scott .
scottl44
01-26-2014, 11:22 AM
Ever since I read that recommendation to leave gaps in the caulk for drainage, I have wanted to know if this is normal and standard since I have never seen such gaps in any stall shower installation I have seen.
If it is normal, then I thought why even caulk the spot where the tile and pan meet? Why not leave the whole joint open since any water that goes in will drain and the air will dry it out.
dhagin
01-26-2014, 11:38 AM
We don't leave gaps, or weep holes, inside of any shower caulking. IMO, weep holes are designed to be used in systems where liquid water is allowed to enter a closed assembly and then needs to have a path for it to leave this assembly.
With properly constructed shower walls, water, in it's liquid form, is not allowed into a closed assembly. The only moisture within this system will be entering in the vapor form, and can escape the same way it came in. :)
eurob
01-26-2014, 12:03 PM
Every opening on the exposed tiled surfaces is a bad idea -- water penetration point , mold housing, etc -- . If your installation has any symptoms of excessive humidity -- wet joints -- for longer periods of time -- called problematic installation -- , weep holes on the bottom can help in resolving somehow the issue .
The thinking behind is to treat it as an exterior brick or stone wall . However the conditions are so far apart . Besides water present on the face of the tiles , no condensation , temperature swings or etc. will be present for an interior shower application .
