3/4" Sched40 under slab repair
DianeDebuda
Texas
This is a water supply line that suddenly started to leak after 3 yr at a 45 connector. Thought it was a crack at first & tried WaterWeld (epoxy), but access is extremely limited because of angle, rock, sidewalk, slabs & other pipes - couldn't get fingers around pipe. Multiple layers of WaterWeld since I thought continued leak was because I wasn't getting it pressed in good enough to seal. Today used demo hammer to remove as much rock as possible at under-slab-hole entrance & under pipe for better access. Still quite limited (coffee can size at 45 degrees to length of pipe) under 5 ft wide sidewalk & below other pipes, but now can at least get fingers around pipe. When tried to chip off excess WaterWeld with screwdriver, 45 degree connector came off pipe. Was able to completely remove connector & "destination side" pipe so now just have "source side" pipe with a mound of WaterWeld on it.
Ideally, I'd like to just cut off 4" inches to get a clean end & glue on a new connector, but cutting access is really tough and visibility is extremely limited. Can barely get fingers around top and back of pipe and don't have 90 degree access, so can't use a normal cutting tool like hacksaw, ratchet cutter, tube cutter or even cable (wire) saw. An internal pvc cutter might work, but all I've been able to find is too big - min for 1-1/4" pipe. An inside coupling would work too if I could find 3/4". Can't find a plug that'd fit inside the pipe to just seal it up. (Other end of pipe is part of manifold under slab, so can't just cut & cap there.)
I've enlarged the access hole about as large as I can get it. Breaking the sidewalk wouldn't help much because of all of the other pipes above & to the back side of the problem pipe. The front side of the hole is at the corner of a garage pad which I'm not willing to break. The only other thing I can think of is using a mini wheel on a Dremel, but have real concerns about getting a good, square cut. Sure wish I'd hadn't put all that WaterWeld on.
Any one have any ideas or sources for 3/4 inside connectors/plugs?
Thanks,
Diane
How much of a "hole" do you think you would have left if you used an "internal coupling"? If you cannot figure out how to do it, call a plumber who will have the tools AND experience to solve your problem. Not every job is a DIY project.
