PVC repair irrigation water supply line from the street
Themp
Active Member
Raleigh, North Carolina
I have a straight 1 inch PVC line from the water meter that got cracked in the middle of the yard. Since I have no flex in the line, unless I dig up a large portion of the line, what is the best way to repair this? I looked at a 1 inch PVC union and it would seem I have to be very exact on getting the two union faces tight because I have no flex that can allow the two sides to move in tighting up the union. My other thought is to just use a flexible 1 inch line and clamps. Or I have to make four 90 degree turns to allow the pipe to flex at the union. Like a large U in the line with the union at the bottom of the U. And this supply line is at 90psi from the city.
Any other tricks?
Thanks, Tom
Or.................use the four 90's without the union.
Point the first set of 90's the same direction, and then drop the length of pipe with the street 90's into the waiting 90's.
If you have room in the ditch, you could also use two 90's for the connection.
