Cottage cheese clog
helwoe
Vancouver, WA
As mentioned in my other thread (plumbing topology) I'm redoing the drain pipe under my home. About 10 years ago I had a major clog and cut a section of the 2" main out and it revealed a white cottage cheese looking clog all the way through the main, though it's a bit gritty and packed in as hard as clay.
I'm replacing the whole thing with 4" and discovered the 2" old main from the kitchen down just past the bath tub is again completely clogged with the same substance in the shape of a crecent with just a sliver clear on the bottom of the pipe! Were very diligent about not dumping any grease or food from the kitchen. One culprit could be dishwasher granule soap. The washing machine is on another seperate main to the drain field so that is eliminated. Anyone have any ideas as to what can cause such a clog? :eek:
TIA
Helwoe!
I found this bit of information (Hard Water Problems ) I wonder if the increased amount of soap because of the effects of hard water are to blame? We definately have hard water. Shower head clogs with lime twice yearly.
Helwoe!
