Submersible Pump Failure #4
mwslaketyler
texas
I am using F&W sub pump single phase 2HP /4 "/55gpm in lake for my irrigation system. I have had to replace the pump several times since install 8 years ago- not only expensive but seems to be during hot season when needed most. I use it with 20 gal tank. It irrigates 2 acre lawn with seperate plant bed zones and a small drip irrigation zone. Is the pump failure continuing problem due to over cycling of the pump? If so what is the solution to this? I have just read of a cycle stop valve-does this work to solve this problem? Does it over-labor the pump? Where do I get a cycle stop valve and how do I spec which model? How do I know if this IS the problem or if something else could be causing it? The installer has placed many,many of same installations and I am not aware of anyone else having the problems I am having. I have also been told the pump should be installed in lake at least at 45 degree angle and not 'laying' on bottom?True?Why? Would a switch to centrifugal pump solve reduce the wearing in any manner or same characteristics or use other than winterizing needs? If there another sub pump manufacturer as good as F&W? Thanks.
let some others chime in on this but...
4 new 2hp subs in 8 yrs... OUCH!! ..around here the irrigation contractor would likely get an old fashioned beat-down after the second one got replaced.. i take it they were just out of warranty? 55gpm pump and 20gal tank running different sized irrigation zones without means to reduce cycling can burn up in a hurry, as you can see! ..he should know better.
buy the cycle stop valve ASAP.. it will make all the difference. valveman will know which is best suited.
A CSV will extend the life of your pump and give you constant pressure. The pump doesn't need to be installed on a 45% angle. I've installed the pumps nearly and they work fine. They should be installed in a sleeve but i've known people that didn't and they worked fine. I suggest that you call Cycle Stop Valves as they will recommend the proper valve and walk you through the installation.
