IPlayPlumber
Hi folks, long time lurker, first time poster.
I am doing a renovation in a basement bathroom in a house built in 1967. I am replacing a fiberglass shower stall with a tub. The drain pipe for the shower is 1 1/2" steel. It was set into the shower drain with lead, it has no threads and sticks up about 3/4" above the concrete floor.
I'm using a tub designed for concrete floors that has a raised bottom to let the tub shoe fit above the floor. It wants the top of the trap adapter to be level with the floor or below. So I need to shorten that drain pipe. I've read enough to know that there are two proper ways of doing this. One would be to cut the pipe below floor level, put a banded coupling on it and a PVC trap adapter. The other would be to excavate down to the trap and remove the pipe from it and replace it with a piece of PVC. If it's threaded use a threaded PVC adapter, otherwise use a donut.
My question: are those my only two options? Neither one is very appealing. To use a banded coupling I'm going to have to go down probably 6", with a hole big enough to cut the pipe 5" below the surface and get a wrench on the coupling, which sounds like a lot of concrete to come out. If I remove the pipe I probably have to go even deeper, and run the risk of breaking the trap.
One thought I have is that the tee for the tub shoe fits nicely into a 1 1/2" banded coupling. Would it be a bad idea just to attach the tee directly to the pipe with a banded coupling? I would still have the tubing going into the 1 1/2" pipe which would prevent obstruction.
Second thought is that the tee has threading on the bottom on the outside. Is there some sort of fitting that the tee is meant to attach too? Is that another option?
Another thought to cut the pipe off flush with the floor, thread it and put a brass trap adapter on.
Do any of these ideas make sense? Or am I just psyching myself out and should get busy breaking concrete.
I appreciate any insights.
Thanks.
Thanks.
