I'm buying a 10 year old home in Fitchburg, WI (Madison area). The basement is exposed with a walkout, so it's not completely below grade like some basements. There is a room in the basement with a utility sink, water softener, water heater and furnace. This room has a covered sump, but no pump. The room has no floor drain, and we're not sure if one exists in the basement. The furnace has a drain tube going into into the sump, so it appears that the sump is being used for drainage instead of a floor drain.
My Realtor thinks that a water heater with no floor drain is a code violation, but I can't find any support for this on the internet. In the WI statutes it states that a floor drain is not necessary with a water heater as long as there is an "approved receptor" (whatever that means). They also state that a floor drain is required only when the basement is entirely below grade, which is not the case here. The plumbing was approved during the initial inspection 10 years ago, so either it's ok to not have a floor drain, or there is a floor drain hidden somewhere under the carpet.
Can somebody please tell me if a floor drain is required by code in this instance, or if it's acceptable to not have one? I'd hate to tear up the carpet or force the seller to install a floor drain unless absolutely necessary. Thanks very much in advance!
