View Full Version : Cracked Tub
OhioMike
04-13-2011, 04:09 AM
While installing my overflow drain I cracked my acrylic tub.:mad: The crack is about 3/4" long up around the overflow hole. Is there any hope of fixing this? Would calling Kohler be a viable repair option?
Thanks for any advice.
Mike
04-13-2011, 09:52 AM
In the yellow pages you will find "tub refinish"
http://www.dexknows.com/local/construction/contractors/refinishing_contractors/geo/c-cincinnati-oh/att/bathtubs/
jadnashua
04-13-2011, 11:44 AM
The washer that seals the overflow is often tapered to allow you to get it parallel with the wall of the tub. If it is not nice an straight, and you tighten things down too much, this could be why it cracked. Some drain systems have a flex joint that allow a flat washer.
