View Full Version : Basement Shower Install
dennis51
04-12-2011, 06:41 PM
Hello,
I am putting in a bathroom in my basement. On the cold wall I put 2 inch pink styrofoam insulation from corning and I then framed a wall over that. the shower is going in the corner where one wall will be next to the pink stuff and the other wall will be against a dry/warm wall. Is the pink stuff good for a vapor barrier against the cold wall, and do I need to put a vapor barrier where the warm wall is? I am going to use Durock Cement Board for the walls.
I appreciate any suggestions
Dennis
cacher_chick
04-12-2011, 08:55 PM
The "pink stuff" is extruded foam, and acts as a vapor retarder. Because of it's fire and smoke spread characteristics, it must be covered with a 15 minute thermal barrier when used indoors. Drywall is the only approved barrier I am aware of, though there might be others.
nitin parashar
04-26-2011, 03:03 AM
Shower must be fitted to the cold side of the tap and you must use a small and handy shower which can be easily fitted and don't create any problem to get fitted and it will fit in small space also.
__________
shower pod (http://www.ukbathroompods.co.uk/)
